It is currently Mon Jul 21, 2025 4:01 am
PostPosted: Wed Jan 24, 2007 2:15 pm
I have a 1/3 hp motor I took out of my old benchtop drillpress I no longer use. Does anybody have any good project ideas I could use this motor for? I considered a buffing wheel or a radius sanding dish, but I'm not sure if the motor will be big enough? Any comments or other ideas?
Thanks!
PostPosted: Wed Jan 24, 2007 2:21 pm
John I power my homebrew buffer with a 1/3 hp 1750 TEFC Baldor motor. It has plenty of power.
PostPosted: Wed Jan 24, 2007 2:23 pm
buffer yes, radius sanding dish no!!! not enough torque.
PostPosted: Wed Jan 24, 2007 3:38 pm
Use it to power an old watchmaker's lathe.
PostPosted: Wed Jan 24, 2007 3:48 pm
First name: Louis
Last Name: Freilicher
City: Belchertown
State: MA
Zip/Postal Code: 01007
[QUOTE=Jocafa] Use it to power an old watchmaker's lathe.[/QUOTE]
Now your talking!! Just got myself a South Bend
- Louis Freilicher
PostPosted: Wed Jan 24, 2007 3:49 pm
I built my buffer with a 1/3 hp and would certainly make myself a ssmall sanding disc for rosette tiles with another one if i'm lucky enough to scrounge another!
PostPosted: Wed Jan 24, 2007 3:57 pm
I'd love to get my hands on a boley, but i'm broke at the moment :T
I've been toying around with the idea of making my own. I've read through
Dave Gingery's books; I just don't know if I'm handy enough to do it.
(sorry, I don't mean to hijack the thread)
If all else fails, you can probably get a fair sum for it on eBay or from one of
us here ;)
PostPosted: Wed Jan 24, 2007 6:02 pm
Last Name: Abercrombie
I had a combo sander with a disk and a 1x42 belt in one unit. A spare motor allowed me to separate the two functions- now 2 machines- so that I could have enough working room around each.
Another junk motor got mounted on end and now is a 3" drum sander.
Just put that motor under your bench and you will find a use for it in a few months.
BTW, I don't know what folks are doing with their radius sanders, but once your 1/3 hp motor is geared down to 50 rpm or so, I think it should have enough torque for most sanding jobs.
PostPosted: Wed Jan 24, 2007 7:57 pm
Bingo ! John . I've been thinking of that drum sander idea. How do you attach the drum ?
I have a 1400 R.P.M. motor.
Cheers CraigKiwiCraig39107.1664814815
CRAIG LAWRENCE of AUSTRALIA
PostPosted: Thu Jan 25, 2007 12:24 am
I run my 12 inch buffer with a 1725 1/5 hp - great - will stall if I press too hard. Good for students, no burn thrus !!!!
PostPosted: Thu Jan 25, 2007 5:13 am
Craig-
Some of the 3-inch drums come ready to bolt on to a half-inch shaft, and that's what I used.
http://www.leevalley.com/wood/page.aspx?c=1&p=20200&cat=1,42 500,42501
I actually used the motor from an oil burner (furnace) which had a flange-type mounting- ideal for a vertical installation.
You can also make a mini-thickness sander by arranging a pivoting table/fence. It's good for messing with bindings, saddles, and bridge shaping.
It helps to have a garage for all your home-built tools(!).
PostPosted: Thu Jan 25, 2007 7:14 am
I saw an article online where someone is building thier own Veritas power sharpening system with such a motor, geared down to 900 - 1200rpm I believe is what the eventual adj speed of the laps.
Anyhoo, Id love to build something like that, sure cant afford the $500+ they want for thiers.
Charliewood
